Learn to improve: A novel deep reinforcement learning approach for beyond 5G network slicing - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Network slicing remains one of the key technologies in 5G and beyond 5G networks (B5G). By leveraging SDN and NVF techniques, it enables the coexistence of several heterogeneous virtual networks (VNs) on top of the same physical infrastructure. Despite the advantages it brings to network operators, network slicing raises a major challenge: Resource allocation of VNs, also known as the virtual network embedding problem (VNEP). VNEP is known to be an NP-Hard problem. Several heuristics, meta-heuristics and Deep Reinforcement Learning (DRL) based solutions were proposed in the literature to solve it. Regarding the first two categories, they can provide a solution for large scale problems within a reasonable time, but the solution is usually suboptimal, which leads to an inefficient utilization of the resources and increases the cost of the allocation process. For DRL-based approaches and due to the explorationexploitation dilemma, the solution can be infeasible. To overcome these issues, we combine, in this work, deep reinforcement learning and relational graph convolutional neural networks in order to automatically learn how to improve the quality of VNEP heuristics. Simulation results show the effectiveness of our approach. Starting with an initial solution given by the heuristics our approach can find an amelioration, with an improvement in the order of 35%.
RGCN_DRL_PAPER.pdf (323.21 Ko) Télécharger le fichier
hal-03510121 , version 1 (04-01-2022)
Anouar Rkhami, Yassine Hadjadj-Aoul, Abdelkader Outtagarts. Learn to improve: A novel deep reinforcement learning approach for beyond 5G network slicing. CCNC 2021 - IEEE 18th Annual Consumer Communications & Networking Conference, Jan 2021, Las Vegas, United States. pp.1-6, ⟨10.1109/CCNC49032.2021.9369463⟩. ⟨hal-03510121⟩
264 Consultations
588 Téléchargements
