Characterization of internal tide incoherence : Eulerian versus Lagrangian perspectives - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Physical Oceanography Année : 2022
The Lagrangian and Eulerian surface current signatures of a low-mode internal tide propagating through a turbulent balanced flow are compared in idealized numerical simulations. Lagrangian and Eulerian total (i.e. coherent plus incoherent) tidal amplitudes are found to be similar. Compared to Eulerian diagnostics, the Lagrangian tidal signal is more incoherent with comparable or smaller incoherence timescales and larger incoherent amplitudes. The larger level of incoherence in Lagrangian data is proposed to result from the deformation of Eulerian internal tide signal induced by drifter displacements. Based on the latter hypothesis, a theoretical model successfully predicts Lagrangian autocovariances by relating Lagrangian and Eulerian autocovariances and the properties of the internal tides and jet. These results have implications for the separation of balanced flow and internal tides signals in the sea level data collected by the future Surface Water and Ocean Topography (SWOT) satellite mission.
608868.pdf"; filename*=UTF-8''608868.pdf (1021.56 Ko) Télécharger le fichier
hal-03514215 , version 1 (05-01-2024)
Zoé Caspar-Cohen, Aurélien Ponte, Noé Lahaye, Xavier Carton, Xiaolong Yu, et al.. Characterization of internal tide incoherence : Eulerian versus Lagrangian perspectives. Journal of Physical Oceanography, 2022, 52 (6), pp.1245-1259. ⟨10.1175/JPO-D-21-0088.1⟩. ⟨hal-03514215⟩
102 Consultations
11 Téléchargements
