Does the level of graphical detail of a virtual handball thrower influence a goalkeeper's motor response? - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Sports Science and Medicine Année : 2009
The authors investigated how different levels of detail (LODs) of a virtual throwing action can influence a handball goalkeeper's motor response. Goalkeepers attempted to stop a virtual ball emanating from five different graphical LODs of the same virtual throwing action. The five levels of detail were: a textured reference level (L0), a non-textured level (L1), a wire-frame level (L2), a point-light-display (PLD) representation (L3) and a PLD level with reduced ball size (L4). For each motor response made by the goalkeeper we measured and analyzed the time to respond (TTR), the percentage of successful motor responses, the distance between the ball and the closest limb (when the stopping motion was incorrect) and the kinematics of the motion. Results showed that TTR, percentage of successful motor responses and distance with the closest limb were not significantly different for any of the five different graphical LODs. However the kinematics of the motion revealed that the trajectory of the stopping limb was significantly different when comparing the L1 and L3 levels, and when comparing the L1 and L4 levels. These differences in the control of the goalkeeper's actions suggests that the different level of information available in the PLD representations (L3 and L4) are causing the goalkeeper to adopt different motor strategies to control the approach of their limb to stop the ball. © Journal of Sports Science and Medicine.
DOC.pdf (544.43 Ko) Télécharger le fichier
hal-03515024 , version 1 (06-01-2022)
  • HAL Id : hal-03515024 , version 1
Nicolas Vignais, Benoît Bideau, Cathy M. Craig, Sébastien Brault, Franck Multon, et al.. Does the level of graphical detail of a virtual handball thrower influence a goalkeeper's motor response?. Journal of Sports Science and Medicine, 2009, 8 (4), pp.501-508. ⟨hal-03515024⟩
241 Consultations
64 Téléchargements
