Analytical Queries on Vanilla RDF Graphs with a Guided Query Builder Approach - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
As more and more data are available as RDF graphs, the availability of tools for data analytics beyond semantic search becomes a key issue of the Semantic Web. Previous work require the modelling of data cubes on top of RDF graphs. We propose an approach that directly answers analytical queries on unmodified (vanilla) RDF graphs by exploiting the computation features of SPARQL 1.1. We rely on the NF design pattern to design a query builder that completely hides SPARQL behind a verbalization in natural language; and that gives intermediate results and suggestions at each step. Our evaluations show that our approach covers a large range of use cases, scales well on large datasets, and is easier to use than writing SPARQL queries.
main-final (1).pdf (285.41 Ko) Télécharger le fichier
hal-03516589 , version 1 (10-01-2022)
  • HAL Id : hal-03516589 , version 1
Sébastien Ferré. Analytical Queries on Vanilla RDF Graphs with a Guided Query Builder Approach. FQAS 2021 - Flexible Query Answering Systems, Sep 2021, Bratislava, Slovakia. ⟨hal-03516589⟩
17 Consultations
89 Téléchargements
