Exploring Labeled Graphs with Recursive Path Patterns - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2022
Amela Fejza
  • Fonction : Auteur
  • PersonId : 1089701
Pierre Genevès
Nabil Layaïda
We demonstrate a system for recursive query answering over labeled graphs. The system is based on a complete implementation of the recent μ-recursive relational algebra, that has been extended with parsers and compilers adapted for queries over property graphs. As a result, one can formulate, optimize and answer queries that navigate recursively along paths in property graphs. We demonstrate the system on three real datasets, including the exploration of chains of drug interactions.
Mots clés
Web
murademo.pdf (1.48 Mo) Télécharger le fichier
hal-03517826 , version 1 (10-01-2022)
hal-03517826 , version 2 (24-10-2022)
hal-03517826 , version 3 (13-01-2023)
hal-03517826 , version 4 (09-11-2023)
  • HAL Id : hal-03517826 , version 1
Amela Fejza, Pierre Genevès, Nabil Layaïda. Exploring Labeled Graphs with Recursive Path Patterns. 2022. ⟨hal-03517826v1⟩
205 Consultations
208 Téléchargements
