Advocating for interdisciplinary collaborations to unravel the astrocyte "Calcium Code" - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2022
In this review article, we advocate for more collaborations across fields working on astrocyte function. As early-career scientists with different backgrounds and expertise, we present the major challenges faced in our fields: data acquisition, analysis and modeling of astrocyte calcium activity. We further highlight the insights gained from those different approaches, aiming at bridging the gap between them to crack the complex astrocyte "Calcium Code". Finally, we propose strategies to promote fruitful interdisciplinary collaborative projects to unravel astrocyte function in health and disease.
ESN2021_covelo_badoual_denizot.pdf (987.38 Ko) Télécharger le fichier
hal-03520863 , version 1 (11-01-2022)
hal-03520863 , version 2 (26-01-2022)
hal-03520863 , version 3 (26-04-2022)
hal-03520863 , version 4 (23-05-2022)
  • HAL Id : hal-03520863 , version 1
Ana Covelo, Anaïs Badoual, Audrey Denizot. Advocating for interdisciplinary collaborations to unravel the astrocyte "Calcium Code". 2022. ⟨hal-03520863v1⟩
271 Consultations
240 Téléchargements
