Quantum Security of the Legendre PRF - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Mathematical Cryptology Année : 2022
In this paper, we study the security of the Legendre PRF against quantum attackers, given classical queries only, and without quantum random-access memories. We give two algorithms that recover the key of a shifted Legendre symbol with unknown shift, with a complexity smaller than the exhaustive search of the key. The first one is a quantum variant of the table-based collision algorithm. The second one is an offline variant of Kuperberg's abelian hidden shift algorithm. We note that the latter, although asymptotically promising, is not currently the most efficient against practical parameters.
legendre.pdf (311.15 Ko) Télécharger le fichier
hal-03529834 , version 1 (17-01-2022)
Paternité
  • HAL Id : hal-03529834 , version 1
Paul Frixons, André Schrottenloher. Quantum Security of the Legendre PRF. Mathematical Cryptology, 2022, 1 (2), pp.52--69. ⟨hal-03529834⟩
Collections
INRIA INRIA2
31 Consultations
34 Téléchargements
