Investigating non lexical markers of the language of schizophrenia in spontaneous conversations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We investigate linguistic markers associated with schizophrenia in clinical conversations by detecting predictive features among Frenchspeaking patients. Dealing with humanhuman dialogues makes for a realistic situation, but it calls for strategies to represent the context and face data sparsity. We compare different approaches for data representation-from individual speech turns to entire conversations-, and data modeling, using lexical, morphological, syntactic, and discourse features, dimensions presumed to be tightly connected to the language of schizophrenia. Previous English models were mostly lexical and reached high performance, here replicated (93.7% acc.). However, our analysis reveals that these models are heavily biased, which probably concerns most datasets on this task. Our new delexicalized models are more general and robust, with the best accuracy score at 77.9%.
codi2021_lisa (1).pdf (238.09 Ko) Télécharger le fichier
hal-03537698 , version 1 (21-01-2022)
Chuyuan Li, Maxime Amblard, Chloé Braud, Caroline Demily, Nicolas Franck, et al.. Investigating non lexical markers of the language of schizophrenia in spontaneous conversations. CODI 2021 - 2nd Workshop on Computational Approaches to Discourse, Nov 2021, Punta Cana, Dominican Republic. pp.20-28, ⟨10.18653/v1/2021.codi-main.3⟩. ⟨hal-03537698⟩
129 Consultations
162 Téléchargements
