g6TiSCH: Generalized 6TiSCH for Agile Multi-PHY Wireless Networking - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Access Année : 2021
Wireless networks traditionally use a single physical layer for communication: some use high bit-rate short-range radios, others low bit-rate long-range radios. This article introduces g6TiSCH, a generalization of the standards-based IETF 6TiSCH protocol stack. g6TiSCH allows nodes equipped with multiple radios to dynamically switch between them on a link-by-link basis, as a function of link-quality. This approach results in a dynamic trade-off between latency and power consumption. We evaluate the performance of the approach experimentally on an indoor office testbed of 36 OpenMote B boards. Each OpenMote B can communicate using FSK 868 MHz, O-QPSK 2.4 GHz or OFDM 868 MHz, a combination of long-range and short-range physical layers. We measure network formation time, end-to-end reliability, end-to-end latency, and battery lifetime. We compare the performance of g6TiSCH against that of a traditional 6TiSCH stack running on each of the three physical layers. Results show that g6TiSCH yields lower latency and network formation time than any of the individual PHYs, while maintaining a similar battery lifetime.
g6TiSCH_Generalized_6TiSCH_for_Agile_Multi-PHY_Wireless_Networking(1).pdf (3.22 Mo) Télécharger le fichier
Origine : Publication financée par une institution
hal-03538208 , version 1 (20-01-2022)
Mina Rady, Quentin Lampin, Dominique Barthel, Thomas Watteyne. g6TiSCH: Generalized 6TiSCH for Agile Multi-PHY Wireless Networking. IEEE Access, 2021, 9, pp.84465-84479. ⟨10.1109/ACCESS.2021.3085967⟩. ⟨hal-03538208⟩
Collections
INRIA INRIA2
61 Consultations
44 Téléchargements
