Online Drone-based Data Gathering Strategies for Ground Sensor Networks - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue International Journal of Sensor Networks Année : 2022
This paper proposes two path-planning schemes for data collection in WSN using a drone flying over the sensor nodes to collect their data. We assign a weight to each sensor node corresponding to its priority in the collection process. When the drone selects its destination node, it will choose the one having the highest weight. We have defined utility functions based on the sensor nodes' information disseminated in the Wireless Sensor Network (WSN) using the Optimized Link State Routing protocol (OLSR). The information required to compute the nodes' weight is added to the exchanged packets during the execution of OLSR. The first proposed strategy is Data-driven Data Gathering Strategy (DDG) which uses the amount of stored data in each sensor node buffer. A priority is given to the nodes having the most significant data amount to collect. The second strategy is called Time-driven Data Gathering Strategy (TDG) where the age of the data is considered.
International_Journal_of_Sensor_Networks____IJSN_2021.pdf (640.98 Ko) Télécharger le fichier
hal-03538548 , version 1 (21-01-2022)
Celia Yasmine Tazibt, Nadjib Achir, Tounsia Djamah. Online Drone-based Data Gathering Strategies for Ground Sensor Networks. International Journal of Sensor Networks, inPress, ⟨10.1504/IJSNET.2022.121702⟩. ⟨hal-03538548⟩
129 Consultations
271 Téléchargements
