GraphSVX: Shapley Value Explanations for Graph Neural Networks - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Graph Neural Networks (GNNs) achieve significant performance for various learning tasks on geometric data due to the incorporation of graph structure into the learning of node representations, which renders their comprehension challenging. In this paper, we first propose a unified framework satisfied by most existing GNN explainers. Then, we introduce GraphSVX, a post hoc local model-agnostic explanation method specifically designed for GNNs. GraphSVX is a decomposition technique that captures the "fair" contribution of each feature and node towards the explained prediction by constructing a surrogate model on a perturbed dataset. It extends to graphs and ultimately provides as explanation the Shapley Values from game theory. Experiments on real-world and synthetic datasets demonstrate that GraphSVX achieves state-ofthe-art performance compared to baseline models while presenting core theoretical and human-centric properties.
GraphSVX_ECML_PKDD_2021.pdf (2.7 Mo) Télécharger le fichier
hal-03539183 , version 1 (21-01-2022)
  • HAL Id : hal-03539183 , version 1
Alexandre Duval, Fragkiskos D. Malliaros. GraphSVX: Shapley Value Explanations for Graph Neural Networks. European Conference on Machine Learning and Knowledge Discovery in Databases (ECML PKDD), Sep 2021, Bilbao, Spain. ⟨hal-03539183⟩
136 Consultations
153 Téléchargements
