Interacting Safely with an Unsafe Environment - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Document Associé À Des Manifestations Scientifiques Année : 2021
We give a presentation of Pure type systems where contexts need not be well-formed and show that this presentation is equivalent to the usual one. The main motivation for this presentation is that, when we extend Pure type systems with computation rules, like in the logical framework DEDUKTI, we want to declare the constants before the computation rules that are needed to check the welltypedness of their type.
LFMTP2021.3.pdf (105.01 Ko) Télécharger le fichier
hal-03540149 , version 1 (23-01-2022)
Gilles Dowek. Interacting Safely with an Unsafe Environment. Logical Frameworks and Meta-Languages, 2021, Pittsburgh, United States. 337, pp.30 - 38, 2021, ⟨10.4204/eptcs.337.3⟩. ⟨hal-03540149⟩
51 Consultations
17 Téléchargements
