An inquisitive account of wh-questions through event semantics - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Maxime Amblard
Maria Boritchev
Philippe de Groote
Question processing is a frequently discussed topic in Natural Language Processing, in particular for chatbots or question and answer systems. However, it is difficult to have a logical representation of questions that can be used in these tasks, let alone automatically produced. We present a compositional method for logically computing the semantic representations of wh-questions. We use compositional Neo-Davidsonian Event Semantics as presented in [10] with thematic roles, joined with Inquisitive Semantics [14]. We implement our encoding using the Abstract Categorial Grammars framework [23]. Our model results in an operationalized view of wh-questions and inquisitive existentials which we illustrate on several examples of wh-questions including who, which and where.
inquisitive-wh-questions-event-semantics.pdf (315.97 Ko) Télécharger le fichier
hal-03541222 , version 1 (29-03-2022)
  • HAL Id : hal-03541222 , version 1
Maxime Amblard, Maria Boritchev, Philippe de Groote. An inquisitive account of wh-questions through event semantics. LACL 2021 - Logical Aspects of Computational Linguistics, Dec 2021, Montpellier (online), France. ⟨hal-03541222⟩
116 Consultations
236 Téléchargements
