Benchmarking learned non-Cartesian k-space trajectories and reconstruction networks - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Poster Année : 2022
We benchmark the current existing methods to jointly learn non-Cartesian k-space trajectory and reconstruction: PILOT, BJORK, and compare them with those obtained from the recently developed generalized hybrid learning (HybLearn) framework. We present the advantages of using projected gradient descent to enforce MR scanner hardware constraints as compared to using added penalties in the cost function. Further, we use the novel HybLearn scheme to jointly learn and compare our results through a retrospective study on fastMRI validation dataset.
main.pdf (2.28 Mo) Télécharger le fichier
hal-03542931 , version 1 (26-01-2022)
Chaithya Giliyar Radhakrishna, Philippe Ciuciu. Benchmarking learned non-Cartesian k-space trajectories and reconstruction networks. Joint Annual Meeting ISMRM-ESMRMB & ISMRT 31st Annual Meeting, May 2022, London, United Kingdom. ⟨hal-03542931⟩
98 Consultations
61 Téléchargements
