Fabrication and Characterization of Nanocomposite Hydrogel Based on Alginate/Nano-Hydroxyapatite Loaded with Linum usitatissimum Extract as a Bone Tissue Engineering Scaffold. - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Marine drugs Année : 2022
M Mohammadpour
  • Fonction : Auteur
H Samadian
  • Fonction : Auteur
N Moradi
  • Fonction : Auteur
Z Izadi
  • Fonction : Auteur
M Eftekhari
  • Fonction : Auteur
M Hamidi
  • Fonction : Auteur
A Shavandi
  • Fonction : Auteur
Cédric Delattre
In the current paper, we fabricated, characterized, and applied nanocomposite hydrogel based on alginate (Alg) and nano-hydroxyapatite (nHA) loaded with phenolic purified extracts from the aerial part of Linum usitatissimum (LOH) as the bone tissue engineering scaffold. nHA was synthesized based on the wet chemical technique/precipitation reaction and incorporated into Alg hydrogel as the filler via physical cross-linking. The characterizations (SEM, DLS, and Zeta potential) revealed that the synthesized nHA possess a plate-like shape with nanometric dimensions. The fabricated nanocomposite has a porous architecture with interconnected pores. The average pore size was in the range of 100-200 mu m and the porosity range of 80-90%. The LOH release measurement showed that about 90% of the loaded drug was released within 12 h followed by a sustained release over 48 h. The in vitro assessments showed that the nanocomposite possesses significant antioxidant activity promoting bone regeneration. The hemolysis induction measurement showed that the nanocomposites were hemocompatible with negligible hemolysis induction. The cell viability/proliferation confirmed the biocompatibility of the nanocomposites, which induced proliferative effects in a dose-dependent manner. This study revealed the fabricated nanocomposites are bioactive and osteoactive applicable for bone tissue engineering applications.
hal-03545395 , version 1 (27-01-2022)
M Mohammadpour, H Samadian, N Moradi, Z Izadi, M Eftekhari, et al.. Fabrication and Characterization of Nanocomposite Hydrogel Based on Alginate/Nano-Hydroxyapatite Loaded with Linum usitatissimum Extract as a Bone Tissue Engineering Scaffold.. Marine drugs, 2022, 20 (1), pp.20. ⟨10.3390/md20010020⟩. ⟨hal-03545395⟩
64 Consultations
0 Téléchargements
