Non-Deterministic Abstract Machines - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2022
We present a generic design of abstract machines for nondeterministic programming languages, such as process calculi or concurrent lambda calculi, that provides a simple way to implement them. Such a machine traverses a term in the search for a redex, making non-deterministic choices when several paths are possible and backtracking when it reaches a dead end, i.e., an irreducible subterm. The search is guaranteed to terminate thanks to term annotations the machine introduces along the way. We show how to automatically derive a non-deterministic abstract machine from a zipper semantics-a form of structural operational semantics in which the decomposition process of a term into a context and a redex is made explicit. The derivation method ensures the soundness and completeness of the machines w.r.t. the zipper semantics.
lics.pdf (652.71 Ko) Télécharger le fichier
hal-03545768 , version 1 (27-01-2022)
hal-03545768 , version 2 (01-07-2022)
  • HAL Id : hal-03545768 , version 1
Małgorzata Biernacka, Dariusz Biernacki, Serguei Lenglet, Alan Schmitt. Non-Deterministic Abstract Machines. 2022. ⟨hal-03545768v1⟩
249 Consultations
165 Téléchargements
