Implementing Linear Bandits in Off-the-Shelf SQLite
The linear multi-armed bandit is a reinforcement learning model that is largely used for sequential decision making in applications such as online advertising and recommender systems. We show that LinUCB, a well-known cumulative reward maximization algorithm for linear bandits, can be implemented in off-the-shelf SQLite. Additionally, our empirical study shows that, when dealing with small bandit data, our SQLite implementation is faster than an implementation in off-the-shelf Python. We believe that our findings open the door for many promising research directions on the topic of in-DBMS federated learning because (i) in the federated learning paradigm, many data owners contribute to the same learning task while locally storing their small data, and (ii) SQLite is a DBMS embedded in billions of devices, hence being able to implement federated learning on top of SQLite is of great practical interest.
