Mathematical analysis of a thermodynamically consistent reduced model for iron corrosion - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Zeitschrift für Angewandte Mathematik und Physik Année : 2023
We are interested in a reduced model for corrosion of iron, in which ferric cations and electrons evolve in a fixed oxide layer subject to a self-consistent electrostatic potential. Reactions at the boundaries are modeled thanks to Butler-Volmer formulas, whereas the boundary conditions on the electrostatic potential model capacitors located at the interfaces between the materials. Our model takes inspiration in existing papers, to which we bring slight modifications in order to make it consistent with thermodynamics and its second principle. Building on a free energy estimate, we establish the global in time existence of a solution to the problem without any restriction on the physical parameters, in opposition to previous works. The proof further relies on uniform estimates on the chemical potentials that are obtained thanks to Moser iterations. Numerical illustrations are finally provided to highlight the similarities and the differences between our new model and the one previously studied in the literature.
vDPCM_preprint.pdf (499.1 Ko) Télécharger le fichier
hal-03549457 , version 1 (31-01-2022)
hal-03549457 , version 2 (19-09-2023)
Clément Cancès, Claire Chainais-Hillairet, Benoît Merlet, Federica Raimondi, Juliette Venel. Mathematical analysis of a thermodynamically consistent reduced model for iron corrosion. Zeitschrift für Angewandte Mathematik und Physik, 2023, 74 (3), pp.96. ⟨10.1007/s00033-023-01970-6⟩. ⟨hal-03549457v1⟩
175 Consultations
162 Téléchargements
