Dirty Paper Coding for Consecutive Messages with Heterogeneous Decoding Deadlines in the Finite Blocklength Regime - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2022
To improve reliability in latency-critical applications, a point-to-point communication system with heterogeneous decoding deadlines is considered. Unlike existing work, this system allows for a message to arrive before the decoding deadline of a prior message. A new coding scheme with finite blocklength codewords is introduced exploiting the dirty paper coding principle. Rigorous bounds are derived for achievable error probabilities. Moreover, numerical results illustrate that the proposed scheme outperforms time sharing for a wide range of blocklengths.
RR-9462.pdf (913.3 Ko) Télécharger le fichier
hal-03556888 , version 1 (24-02-2022)
  • HAL Id : hal-03556888 , version 1
Homa Nikbakht, Malcolm Egan, Jean-Marie Gorce. Dirty Paper Coding for Consecutive Messages with Heterogeneous Decoding Deadlines in the Finite Blocklength Regime. [Research Report] RR-9462, Inria - Research Centre Grenoble – Rhône-Alpes. 2022, pp.1-21. ⟨hal-03556888⟩
88 Consultations
152 Téléchargements
