Achievable Information-Energy Region in the Finite Block-Length Regime with Finite Constellations - Archive ouverte HAL Access content directly
Conference Papers Year :
This paper characterizes an achievable information-energy region of simultaneous information and energy transmission over an additive white Gaussian noise channel. This analysis is performed in the finite block-length regime with finite constellations. More specifically, a method for constructing a family of codes is proposed and the set of achievable tuples of information rate, energy rate, decoding error probability (DEP) and energy outage probability (EOP) is characterized. Using existing converse results, it is shown that the construction is information rate, energy rate, and EOP optimal. The achieved DEP is, however, sub-optimal.
Achievable Information-Energy Region in the Finite Block-Length Regime with Finite Constellations.pdf (503.22 Ko) Télécharger le fichier
Dates and versions
hal-03563756 , version 1 (09-02-2022)
Identifiers
Cite
Sadaf Ul Zuhra, Samir M. Perlaza, H. Vincent Poor, Eitan Altman. Achievable Information-Energy Region in the Finite Block-Length Regime with Finite Constellations. ISIT 2022 - IEEE International Symposium on Information Theory, Jun 2022, Espoo, Finland. pp.2106-2111, ⟨10.1109/ISIT50566.2022.9834694⟩. ⟨hal-03563756⟩
163 View
159 Download
Share
