Achievable Information-Energy Region in the Finite Block-Length Regime with Finite Constellations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This paper characterizes an achievable information-energy region of simultaneous information and energy transmission over an additive white Gaussian noise channel. This analysis is performed in the finite block-length regime with finite constellations. More specifically, a method for constructing a family of codes is proposed and the set of achievable tuples of information rate, energy rate, decoding error probability (DEP) and energy outage probability (EOP) is characterized. Using existing converse results, it is shown that the construction is information rate, energy rate, and EOP optimal. The achieved DEP is, however, sub-optimal.
Achievable Information-Energy Region in the Finite Block-Length Regime with Finite Constellations.pdf (503.22 Ko) Télécharger le fichier
hal-03563756 , version 1 (09-02-2022)
Sadaf Ul Zuhra, Samir M. Perlaza, H. Vincent Poor, Eitan Altman. Achievable Information-Energy Region in the Finite Block-Length Regime with Finite Constellations. ISIT 2022 - IEEE International Symposium on Information Theory, Jun 2022, Espoo, Finland. pp.2106-2111, ⟨10.1109/ISIT50566.2022.9834694⟩. ⟨hal-03563756⟩
180 Consultations
210 Téléchargements
