Trans-Translation Is an Appealing Target for the Development of New Antimicrobial Compounds - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Microorganisms Année : 2022
Because of the ever-increasing multidrug resistance in microorganisms, it is crucial that we find and develop new antibiotics, especially molecules with different targets and mechanisms of action than those of the antibiotics in use today. Translation is a fundamental process that uses a large portion of the cell's energy, and the ribosome is already the target of more than half of the antibiotics in clinical use. However, this process is highly regulated, and its quality control machinery is actively studied as a possible target for new inhibitors. In bacteria, ribosomal stalling is a frequent event that jeopardizes bacterial wellness, and the most severe form occurs when ribosomes stall at the 3 '-end of mRNA molecules devoid of a stop codon. Trans-translation is the principal and most sophisticated quality control mechanism for solving this problem, which would otherwise result in inefficient or even toxic protein synthesis. It is based on the complex made by tmRNA and SmpB, and because trans-translation is absent in eukaryotes, but necessary for bacterial fitness or survival, it is an exciting and realistic target for new antibiotics. Here, we describe the current and future prospects for developing what we hope will be a novel generation of trans-translation inhibitors.
microorganisms-10-00003-v2.pdf (2.31 Mo) Télécharger le fichier
hal-03575603 , version 1 (06-05-2022)
Rodrigo Campos-Silva, Gaetano d'Urso, Olivier Delalande, Emmanuel Giudice, Alexandre Jose Macedo, et al.. Trans-Translation Is an Appealing Target for the Development of New Antimicrobial Compounds. Microorganisms, 2022, 10 (1), pp.3. ⟨10.3390/microorganisms10010003⟩. ⟨hal-03575603⟩
45 Consultations
21 Téléchargements
