Efficient Kernel UCB for Contextual Bandits
In this paper, we tackle the computational efficiency of kernelized UCB algorithms in contextual bandits. While standard methods require a $O(CT^3)$ complexity where $T$ is the horizon and the constant $C$ is related to optimizing the UCB rule, we propose an efficient contextual algorithm for large-scale problems. Specifically, our method relies on incremental Nyström approximations of the joint kernel embedding of contexts and actions. This allows us to achieve a complexity of $O(CT m^2)$ where $m$ is the number of Nyström points. To recover the same regret as the standard kernelized UCB algorithm, m needs to be of order of the effective dimension of the problem, which is at most $O(\sqrt{T})$ and nearly constant in some cases.
