Comparison of control methods for 2D industrial cranes - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2022
This paper aims to review and compare some methods used to control 2D overhead cranes. The properties of the controllers are categorized based on their structure, feedback type (open-loop, collocated, and noncollocated), and their stability (local, global, regulation and tracking). Subsequently, a new model is used to describe the system's behavior more accurately. The model consists of a pendulum with a large number of links attached to a cart, allowing to study global nonlinearities as well as cables' flexibility and vibration, simultaneously. The controllers are then studied by extensive numerical simulations under the regulation and tracking scenarios.
ieeeconf .pdf (412.83 Ko) Télécharger le fichier
hal-03580580 , version 1 (18-02-2022)
hal-03580580 , version 2 (12-12-2022)
  • HAL Id : hal-03580580 , version 1
Mohammad Rasool Mojallizadeh, Bernard Brogliato, Christophe Prieur. Comparison of control methods for 2D industrial cranes. 2022. ⟨hal-03580580v1⟩
167 Consultations
149 Téléchargements
