Symbolic-Numeric Factorization of Differential Operators - Archive ouverte HAL Access content directly
Conference Papers Year :
Factorisation Symbolique-Numérique d'Opérateurs Différentiels
We present a symbolic-numeric Las Vegas algorithm for factoring Fuchsian ordinary differential operators with rational function coefficients. The new algorithm combines ideas of van Hoeij's "local-to-global" method and of the "analytic" approach proposed by van der Hoeven. It essentially reduces to the former in "easy" cases where the local-to-global method succeeds, and to an optimized variant of the latter in the "hardest" cases, while handling intermediate cases more efficiently than both.
issac22.pdf (305.85 Ko) Télécharger le fichier
Dates and versions
hal-03580658 , version 1 (18-02-2022)
hal-03580658 , version 2 (18-05-2022)
hal-03580658 , version 3 (31-05-2022)
hal-03580658 , version 4 (02-06-2022)
Identifiers
Cite
Frédéric Chyzak, Alexandre Goyer, Marc Mezzarobba. Symbolic-Numeric Factorization of Differential Operators. ISSAC '22, Jul 2022, Lille, France. ⟨10.1145/3476446.3535503⟩. ⟨hal-03580658v4⟩
181 View
156 Download
Share
