A Formalisation of Algorithms for Sorting Network - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2022
This notes explains how standard algorithms that construct sorting networks have been formalised and proved correct in the Coq proof assistant using the SSReflect extension.
Note.pdf (187.18 Ko) Télécharger le fichier
hal-03585618 , version 1 (24-02-2022)
hal-03585618 , version 2 (02-03-2022)
Laurent Théry. A Formalisation of Algorithms for Sorting Network. 2022. ⟨hal-03585618v2⟩
57 Consultations
104 Téléchargements
