Lack of local controllability for a water-tank system when the time is not large enough - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2022
We consider the small-time local controllability property of a water tank modeled by 1D Saint-Venant equations, where the control is the acceleration of the tank. It is known from the work of Dubois et al. that the linearized system is not controllable. Moreover, concerning the linearized system, they showed that a traveling time * is necessary to bring the tank from one position to another for which the water is still at the beginning and at the end. Concerning the nonlinear system, Coron showed that local controllability around equilibrium states holds for a time large enough. In this paper, we show that for the local controllability of the nonlinear system around the equilibrium states, the necessary time is at least 2 * even for the tank being still at the beginning and at the end. The key point of the proof is a coercivity property for the quadratic approximation of the water-tank system.
main.pdf (509.71 Ko) Télécharger le fichier
Origine Fichiers produits par l'(les) auteur(s)
hal-03588552 , version 1 (25-02-2022)
hal-03588552 , version 2 (20-12-2022)
  • HAL Id : hal-03588552 , version 1
Jean-Michel Coron, Hoai-Minh Nguyen, Armand Koenig. Lack of local controllability for a water-tank system when the time is not large enough. 2022. ⟨hal-03588552v1⟩
159 Consultations
104 Téléchargements
Gmail Mastodon Facebook X LinkedIn More
