φ-FEM: an optimally convergent and easily implementable immersed boundary method for particulate flows and Stokes equations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2022
We present an immersed boundary method to simulate the creeping motion of a rigid particle in a fluid described by the Stokes equations discretized thanks to a finite element strategy on unfitted meshes, called φ-FEM, that uses the description of the solid with a level-set function. One of the advantages of our method is the use of standard finite element spaces and classical integration tools, while maintaining the optimal convergence (theoretically in the H¹ norm for the velocity and L² for pressure; numerically also in the L² norm for the velocity).
main.pdf (1.81 Mo) Télécharger le fichier
hal-03588715 , version 1 (08-03-2022)
hal-03588715 , version 2 (02-11-2022)
hal-03588715 , version 3 (13-11-2022)
hal-03588715 , version 4 (27-01-2023)
  • HAL Id : hal-03588715 , version 2
Michel Duprez, Vanessa Lleras, Alexei Lozinski. φ-FEM: an optimally convergent and easily implementable immersed boundary method for particulate flows and Stokes equations. 2022. ⟨hal-03588715v2⟩
215 Consultations
140 Téléchargements
