A Signature-based Algorithm for Computing the Nondegenerate Locus of a Polynomial System - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2022
Polynomial system solving arises in many application areas to model non-linear geometric properties. In such settings, polynomial systems may come with degeneration which the end-user wants to exclude from the solution set. The nondegenerate locus of a polynomial system is the set of points where the codimension of the solution set matches the number of equations. Computing the nondegenerate locus is classically done through ideal-theoretic operations in commutative algebra such as saturation ideals or equidimensional decompositions to extract the component of maximal codimension. By exploiting the algebraic features of signature-based Gröbner basis algorithms we design an algorithm which computes a Gröbner basis of the equations describing the closure of the nondegenerate locus of a polynomial system, without computing first a Gröbner basis for the whole polynomial system.
sgb_nondegen.pdf (527.59 Ko) Télécharger le fichier
hal-03590675 , version 1 (28-02-2022)
hal-03590675 , version 2 (22-02-2023)
hal-03590675 , version 3 (23-02-2023)
hal-03590675 , version 4 (10-03-2023)
  • HAL Id : hal-03590675 , version 1
Christian Eder, Pierre Lairez, Rafael Mohr, Mohab Safey El Din. A Signature-based Algorithm for Computing the Nondegenerate Locus of a Polynomial System. 2022. ⟨hal-03590675v1⟩
397 Consultations
136 Téléchargements
