First equilibrium reconstruction for ITER with the code NICE - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2021
In this short paper we present the first application of the IMAS compatible code NICE to equilibrium reconstrution for ITER geometry. The inverse problem is formulated as a least square problem and the numerical methods implemented in NICE in order to solve it are presented. The results of a numerical experiment are shown: a reference equilibrium is computed from which a set of synthetic magnetic measurements are extracted. Then these measurements are used successfully to reconstruct the equilibrium of the plasma.
hal-03590775 , version 1 (10-11-2021)
hal-03590775 , version 2 (28-02-2022)
Blaise Faugeras, Jacques Blum, Cedric Boulbe. First equilibrium reconstruction for ITER with the code NICE. 2021. ⟨hal-03590775v1⟩
110 Consultations
0 Téléchargements
