Branch-Cut-and-Price algorithm for an Operational Storage Location Assignment Problem - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The Storage Location Assignment Problem in warehousing have been seldomly tackled by exact methods when considering the exact demand over a time horizon (e.g. the set of orders with different items to retrieve). In this presentation we present a novel extended formulation of the problem that is independant from both: i. the warehouse layout and ii. The picker routing policy. These two aspects are convexified in the subproblems. This formulation is solved by a column-generation algorithm with decomposed pricing problems, embedded in a Branch-Cut-and-Price. Several polynomial and exponential families of valid inequalities are derived to enhance the resolution framework. Preliminary results show a major improvement of the dual bound between a compact mixed-integer formulation and the extended one. The results of the Branch-Cut-and-Price algorithm are competitive compared to commercial solvers. Further work is ongoing to further speed-up the solution method.
ROADEF_2022.pdf (207.35 Ko) Télécharger le fichier
hal-03595258 , version 1 (03-03-2022)
  • HAL Id : hal-03595258 , version 1
Thibault Prunet, Nabil Absi, Valeria Borodin, Diego Cattaruzza. Branch-Cut-and-Price algorithm for an Operational Storage Location Assignment Problem. ROADEF 2022 - 23ème congrès annuel de la Société Française de Recherche Opérationnelle et d'Aide à la Décision, INSA Lyon, Feb 2022, Villeurbanne - Lyon, France. ⟨hal-03595258⟩
93 Consultations
83 Téléchargements
