A central limit and Berry-Esseen theorem for continuous-time Markov processes conditioned not to be absorbed - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2022
This paper aims to establish a central limit and Berry-Esseen-like theorem for Markov processes conditioned not to be absorbed. First, we prove that a central limit theorem holds true for the $Q$-process, under general criteria on its exponential ergodicity. Then, we prove that the Kolmogorov distance between the conditional distribution of the renormalized centered empirical mean for the absorbed process and the one for the $Q$-process decays as $1/\sqrt{t}$.
02.03.2022-CTL-QSD.pdf (425.1 Ko) Télécharger le fichier
hal-03599148 , version 1 (06-03-2022)
hal-03599148 , version 2 (31-03-2022)
hal-03599148 , version 3 (30-03-2023)
William Oçafrain. A central limit and Berry-Esseen theorem for continuous-time Markov processes conditioned not to be absorbed. 2022. ⟨hal-03599148v2⟩
84 Consultations
84 Téléchargements
