On the use of a local $\hat R$ to improve MCMC convergence diagnostic - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2022
Diagnosing convergence of Markov chain Monte Carlo is crucial and remains an essentially unsolved problem. Among the most popular methods, the potential scale reduction factor, commonly named $\hat R$, is an indicator that monitors the convergence of output chains to a target distribution, based on a comparison of the between-and within-variances. Several improvements have been suggested since its introduction in the 90s. Here, we aim at better understanding the $\hat R$ behaviour by proposing a localized version that focuses on quantiles of the target distribution. This new version relies on key theoretical properties of the associated population value. It naturally leads to proposing a new indicator $\hat R_\infty$, which is shown to allow both for localizing the Markov chain Monte Carlo convergence in different quantiles of the target distribution, and at the same time for handling some convergence issues not detected by other $\hat R$ versions.
Moins_Rhat.pdf (1.17 Mo) Télécharger le fichier
hal-03600407 , version 1 (07-03-2022)
hal-03600407 , version 2 (07-03-2023)
  • HAL Id : hal-03600407 , version 1
Théo Moins, Julyan Arbel, Anne Dutfoy, Stéphane Girard. On the use of a local $\hat R$ to improve MCMC convergence diagnostic. 2022. ⟨hal-03600407v1⟩
147 Consultations
218 Téléchargements
