Analysis of the implicit Euler time-discretization of semi-explicit differential-algebraic linear complementarity systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue SIAM Journal on Control and Optimization Année : 2022
This article is largely concerned with the time-discretization of differential-algebraic equations (DAE) with complementarity constraints, which we name differential algebraic linear complementarity systems (DALCS). Specifically, the Euler implicit discretization of DALCS is analysed: the one-step non-smooth problem (OSNSP), that is a generalized equation, is shown to be wellposed under some conditions, then the convergence of the discretized solutions is studied, and the existence of solutions to the continuous-time system is shown as a consequence. Passivity of some operators is pivotal to the analysis. Examples from circuits, mechanics and switching DAE illustrate the applicability of the developments.
MLCS3_SICON_v2.pdf (571.06 Ko) Télécharger le fichier
hal-03606276 , version 1 (11-03-2022)
hal-03606276 , version 2 (11-04-2022)
  • HAL Id : hal-03606276 , version 1
Bernard Brogliato. Analysis of the implicit Euler time-discretization of semi-explicit differential-algebraic linear complementarity systems. SIAM Journal on Control and Optimization, In press. ⟨hal-03606276v1⟩
151 Consultations
189 Téléchargements
