Modular curves over number fields and ECM - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2022
We use genus 1 modular curves X1(M1, M2) where M1 | M2 to construct families of elliptic curves defined over number fields and containing torsion groups Z/M1Z × Z/M2Z. The reductions of these curves can be used to speed up ECM for factoring numbers with special properties, a typical example being (factors of) Cunningham numbers b^ n +/ − 1 such that n | M1.
nbfields.pdf (342.59 Ko) Télécharger le fichier
hal-03606355 , version 1 (11-03-2022)
hal-03606355 , version 2 (09-01-2023)
  • HAL Id : hal-03606355 , version 1
François Morain. Modular curves over number fields and ECM. 2022. ⟨hal-03606355v1⟩
190 Consultations
274 Téléchargements
