Estimating Drill String Friction with Model-Based and Data-Driven Methods - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Estimation of the behavior of long dynamic systems with limited sensing remains an open question. In this paper, we consider the rotational motion of a deep drilling system and compare three algorithms to estimate the friction factors along the drillstring and thus provide an estimate of bottomhole rotational velocity. These friction terms characterize the interaction between the drill pipe and the wellbore walls (Coulomb source terms) within the curving wellbore. This information is essential to design the next generation of stick-slip mitigation controllers, to develop real-time wellbore monitoring tools, and to enable effective toolface control for directional drilling. We propose two model-based algorithms (an adaptive observer and a recursive dynamics framework) and a machine learning-based algorithm to estimate friction parameters, all of them presenting advantages and drawbacks. The performances of the two model-based estimators are finally compared with the data-driven neural network.
ACC21_Machine_Learning-2.pdf (354.31 Ko) Télécharger le fichier
hal-03608695 , version 1 (15-03-2022)
Jean Auriol, Roman Shor, Silviu-Iulian Niculescu, Nasser Kazemi. Estimating Drill String Friction with Model-Based and Data-Driven Methods. 2022 American Control Conference (ACC 2022), Jun 2022, Atlanta, United States. ⟨10.23919/acc53348.2022.9867526⟩. ⟨hal-03608695⟩
115 Consultations
95 Téléchargements
