Characterization of a novel strain of Aspergillus aculeatinus: From rhamnogalacturonan type I pectin degradation to improvement of fruit juice filtration - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Carbohydrate Polymers Année : 2021
Catalina Duran Garzon
  • Fonction : Auteur
  • PersonId : 1222331
  • IdRef : 235452769
Olivier Habrylo
Anais Guillaume
  • Fonction : Auteur
Clemence Millet
  • Fonction : Auteur
Catherine Fourtot-Brun
  • Fonction : Auteur
Pascal Le Blond
  • Fonction : Auteur
Aurore Perrin
  • Fonction : Auteur
Yves Coutel
  • Fonction : Auteur
Loic Levavasseur
  • Fonction : Auteur
Aspergillus spp. are well-known producers of pectinases commonly used in the industry. Aspergillus aculeatinus is a recently identified species but poorly characterized. This study aimed at giving a comprehensive characterization of the enzymatic potential of the O822 strain to produce Rhamnogalacturonan type I (RGI)-degrading enzymes. Proteomic analysis identified cell wall degrading enzymes (cellulases, hemicellulases, and pectinases) that accounted for 92 % of total secreted proteins. Twelve out of fifty proteins were identified as RGI-degrading enzymes. NMR and enzymatic assays revealed high levels of arabinofuranosidase, arabinanase, galactanase, rhamnogalacturonan hydrolases and rhamnogalacturonan acetylesterase activities in aqueous extracts. Viscosity assays carried out with RGI-rich camelina mucilage confirmed the efficiency of enzymes secreted by O822 to hydrolyze RGI, by decreasing viscosity by 70 %. Apple juice trials carried out at laboratory and pilot scale showed an increase in filtration flow rate and yield, paving the way for an industrial use of enzymes derived from A. aculeatinus.
S0144861721003301.pdf (1.46 Mo) Télécharger le fichier
hal-03610098 , version 1 (24-04-2023)
Paternité - Pas d'utilisation commerciale
Catalina Duran Garzon, Olivier Habrylo, Adrien Lemaire, Anais Guillaume, Yoann Carre, et al.. Characterization of a novel strain of Aspergillus aculeatinus: From rhamnogalacturonan type I pectin degradation to improvement of fruit juice filtration. Carbohydrate Polymers, 2021, 262, pp.117943. ⟨10.1016/j.carbpol.2021.117943⟩. ⟨hal-03610098⟩
63 Consultations
4 Téléchargements
