Heat management and losses of electrocaloric cooling devices based on electrostatic thermal switches - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Applied Thermal Engineering Année : 2022
Electrocaloric cooling is a promising technology that could replace existing vapor-compression technology with lighter and more efficient solid state based devices. Among those, electrocaloric coolers using electrostatic actuation are rising; therefore harnessing their advantages and understanding their shortcomings is still a work in progress. In this paper, we pin down two limitations that stem from a commonly used device design, and we propose a model that takes them into account. The first is due to the displacement of the film, which moves the air around and causes losses. We estimate the air losses through a Poiseuille flow model. The second is related to the non-ideal Brayton cycle the device performs and which results in generating a heat flow opposite to cooling. We estimated the effect of this back-flow on the cold flux using a 2D thermal diffusion model. Ultimately, our results point at several possible improvements for further designs. Among them, a slight reduction of the air pressure in the device looks as a promising solution to reduce air losses.
Lucas_electrocaloric_cooling_THERMAG.pdf (785.73 Ko) Télécharger le fichier
hal-03616477 , version 1 (22-03-2022)
Lucas Depreux, Morgan Almanza, Nouh Zeggai, Fabien Parrain, Martino Lobue. Heat management and losses of electrocaloric cooling devices based on electrostatic thermal switches. Applied Thermal Engineering, 2022, pp.118290. ⟨10.1016/j.applthermaleng.2022.118290⟩. ⟨hal-03616477⟩
128 Consultations
139 Téléchargements
