Identifying genes with conserved splicing structure and orthologous isoforms in human, mouse and dog - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue BMC Genomics Année : 2022
Background: In eukaryote transcriptomes, a significant amount of transcript diversity comes from genes' capacity to generate different transcripts through alternative splicing. Identifying orthologous alternative transcripts across multiple species is of particular interest for genome annotators. However, there is no formal definition of transcript orthology based on the splicing structure conservation. Likewise there is no public dataset benchmark providing groups of orthologous transcripts sharing a conserved splicing structure. Results: We introduced a formal definition of splicing structure orthology and we predicted transcript orthologs in human, mouse and dog. Applying a selective strategy, we analyzed 2,167 genes and their 18,109 known transcripts and identified a set of 253 gene orthologs that shared a conserved splicing structure in all three species. We predicted 6,861 transcript CDSs (coding sequence), mainly for dog, an emergent model species. Each predicted transcript was an ortholog of a known transcript: both share the same CDS splicing structure. Evidence for the existence of the predicted CDSs was found in external data. Conclusions: We generated a dataset of 253 gene triplets, structurally conserved and sharing all their CDSs in human, mouse and dog, which correspond to 879 triplets of spliced CDS orthologs. We have released the dataset both as an SQL database and as tabulated files. The data consists of the 879 CDS orthology groups with their detailed splicing structures, and the predicted CDSs, associated with their experimental evidence. The 6,861 predicted CDSs are provided in GTF files. Our data may contribute to compare highly conserved genes across three species, for comparative transcriptomics at the isoform level, or for benchmarking splice aligners and methods focusing on the identification of splicing orthologs. The data is available at https://data-access.cesgo.org/index.php/s/V97GXxOS66NqTkZ.
Guillaudeux_et_al-2022-BMC_Genomics.pdf (2.57 Mo) Télécharger le fichier
hal-03616626 , version 1 (22-03-2022)
Paternité
Nicolas Guillaudeux, Catherine Belleannée, Samuel Blanquart. Identifying genes with conserved splicing structure and orthologous isoforms in human, mouse and dog. BMC Genomics, 2022, 23 (1), pp.1-14. ⟨10.1186/s12864-022-08429-4⟩. ⟨hal-03616626⟩
64 Consultations
31 Téléchargements
