Modelling Sustainability in Cyber-Physical Systems: A Systematic Mapping Study - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2022
Supporting sustainability through modelling and analysis has become an active area of research in Software Engineering. Therefore, it is important and timely to survey the current state of the art in sustainability in Cyber-Physical Systems (CPS), which is one of the most actively developing classes of complex software systems. This work discusses the results of a Systematic Mapping Study (SMS) aiming at identifying the relevant primary studies reporting on CPS modelling approaches addressing sustainability over the last 10 years. Our literature search yielded 2209 papers, of which 105 primary studies were deemed relevant for a detailed characterisation from the perspective of nine research questions, to extract information about sustainability attributes, methods, models/metamodels, metrics, processes and tools used to improve the sustainability of CPS. These questions also aimed at collecting data about domain-specific modelling approaches and application domains. The final results report on nine questions, highlight interesting correlations among them, and identify literature gaps worth investigating in the near future.
Sustainable_CPS_SMS__till_2021.pdf (1.05 Mo) Télécharger le fichier
hal-03616678 , version 1 (23-03-2022)
  • HAL Id : hal-03616678 , version 1
Ankica Barisic, Jácome Cunha, Ivan Ruchkin, Ana Moreira, João Araújo, et al.. Modelling Sustainability in Cyber-Physical Systems: A Systematic Mapping Study. 2022. ⟨hal-03616678⟩
123 Consultations
282 Téléchargements
