A linearization method based on Lie algebra for pose estimation in a time horizon - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In this paper, a strategy for linear pose estimation over a time horizon is presented. This linearization is crucial for the computationally efficient formulation of predictive and optimization-based control problems in robotics. The proposed approach is based on a truncation of the Magnus expansion for the approximation of the exponential map derivative and employs Lie algebra to represent position and orientation, allowing for a unified vectorial representation in vector form that can be integrated linearly over time, offering a convenient formulation for optimization solvers. The method shows promising results for precision and computation times.
ARK2022___A_linearization_method_based_on_Lie_algebra_for_pose_estimation_in_a_time_horizon.pdf (1.35 Mo) Télécharger le fichier
hal-03621688 , version 1 (28-03-2022)
hal-03621688 , version 2 (28-03-2022)
hal-03621688 , version 3 (31-03-2022)
  • HAL Id : hal-03621688 , version 1
Nicolas Torres Alberto, Lucas Joseph, Vincent Padois, David Daney. A linearization method based on Lie algebra for pose estimation in a time horizon. ARK 2022 - 18th International Symposium on Advances in Robot Kinematics, Jun 2022, Bilbao, Spain. ⟨hal-03621688v1⟩
178 Consultations
220 Téléchargements
