Two-dimensional periodic structures modeling based on second strain gradient elasticity for a beam grid - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue International Journal of Mechanical Sciences Année : 2022
Higher order gradient elasticity theories are widely applied to determine the wave propagation characteristics of microsized structures. The novelty of this paper, firstly, is using the Second Strain Gradient (SSG) theory to explore the mechanism of a micro-sized 2D beam grid. The strong formulas of continuum model including governing equations and boundary conditions are derived by using the Hamilton principle. Then, a valuable long-range Lattice Spring Model (LSM) is elaborated, providing a reasonable explanation for the model based on SSG theory. The dynamic continuum equations from LSM are calculated through the Fourier series transform approach. Finally, the dynamic properties of 2D beam grid are analyzed within the Wave Finite Element Method (WFEM) framework. The band structure and slowness surfaces, confined to the irreducible first Brillouin zone, are studied in frequency spectrum. The energy flow vector fields and wave beaming effects are discussed through SSG theory and Classical Theory (CT) of elasticity. The results show that the proposed approach is of significant potential for investigating the 2D wave propagation characteristics of complex micro-sized periodic structures.
2022_Yang_IJMS.pdf (4.65 Mo) Télécharger le fichier
hal-03622173 , version 1 (28-03-2022)
Bo Yang, Abdelmalek Zine, Christophe Droz, Mohamed Ichchou. Two-dimensional periodic structures modeling based on second strain gradient elasticity for a beam grid. International Journal of Mechanical Sciences, 2022, 222, pp.1-13. ⟨10.1016/j.ijmecsci.2022.107199⟩. ⟨hal-03622173⟩
77 Consultations
124 Téléchargements
