Uniform $C^{1,\alpha}$-regularity for almost-minimizers of some nonlocal perturbations of the perimeter - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2022
In this paper, we establish a $C^{1,\alpha}$-regularity theorem for almost-minimizers of a functional $\mathcal{F}_{\varepsilon,\gamma}=P-\gamma P_{\varepsilon}$, where $\gamma\in (0,1)$ and $P_{\varepsilon}$ is a nonlocal energy converging to the perimeter as $\varepsilon$ vanishes. Our theorem provides a criterion for $C^{1,\alpha}$-regularity at a point of the boundary, which is uniform as the parameter $\varepsilon$ goes to $0$. Building upon previous work by the last two authors, as an application of this theorem we obtain that volume-constrained global minimizers of $\mathcal{F}_{\varepsilon,\gamma}$ are balls for any $\varepsilon$ small enough. For small $\varepsilon$, this minimization problem corresponds to the large mass regime for a Gamow-type problem where the nonlocal repulsive term is given by an integrable kernel $G$ with sufficiently fast decay at infinity.
uniform_regularity_hal1.pdf (749.77 Ko) Télécharger le fichier
fig1.pdf (31.23 Ko) Télécharger le fichier
fig1b.pdf (41.29 Ko) Télécharger le fichier
fig2.pdf (31.27 Ko) Télécharger le fichier
Format : Figure, Image
hal-03623418 , version 1 (29-03-2022)
hal-03623418 , version 2 (16-08-2022)
hal-03623418 , version 3 (22-09-2022)
  • HAL Id : hal-03623418 , version 1
Michael Goldman, Benoît Merlet, Marc Pegon. Uniform $C^{1,\alpha}$-regularity for almost-minimizers of some nonlocal perturbations of the perimeter. 2022. ⟨hal-03623418v1⟩
211 Consultations
80 Téléchargements
