Fast and stable schemes for non-linear osmosis filtering - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2022
We consider a non-linear variant of the transport-diffusion osmosis model for solving a variety of imaging problems such as shadow/soft-light removal and compact data representation. The non-linear behaviour is encoded in terms of a general scalar function g with suitable properties, which allows to balance the diffusion intensity on the different regions of the image while preventing smoothing artefacts. For the proposed model, conservation properties (intensity and non-negativity) are proved and a variational interpretation is showed for specific choices of g. Upon suitable spatial discretisation, both an explicit and a semi-implicit iterative scheme are considered, for which convergence restrictions and unconditional stability are proved, respectively. To validate the proposed modelling and the computational speed of the numerical schemes considered, we report several results and comparisons for the problem of shadow/light-spot removal and compact data representation, showing that artefact-free and computationally efficient results are obtained in comparison to standard linear and anisotropic models, and state-of-the art approaches.
hal-03624486 , version 1 (30-03-2022)
Luca Calatroni, S. Morigi, S. Parisotto, G. A. Recupero. Fast and stable schemes for non-linear osmosis filtering. 2022. ⟨hal-03624486⟩
32 Consultations
0 Téléchargements
