Multiplicity-Induced-Dominancy property for second-order neutral differential equations with application in oscillation damping - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue European Journal of Control Année : 2023
This paper addresses the exponential stability of linear time-delay systems of neutral type. In general, it is quite a challenge to establish conditions on the parameters of the system in order to guarantee such a stability. Recent works emphasized the link between maximal multiplicity and dominant roots. Indeed, conditions for a given multiple root to be necessarily dominant are investigated, this property is known as Multiplicity-Induced-Dominancy (MID). The aim of this paper is to explore the effect of multiple roots with admissible multiplicities exhibiting, under appropriate conditions, the validity of the MID property for second-order neutral time-delay differential equations with a single delay. The ensuing control methodology is summarized in a five-steps algorithm that can be exploited in the design of higher-order systems. The main ingredient of the proposed method is the dominancy proof for multiple spectral values based on frequency bounds established via integral equations. As an illustration, the stabilization of the classical oscillator benefits from the obtained results.
Paper_EJC_2022.pdf (517.93 Ko) Télécharger le fichier
hal-03626756 , version 1 (01-09-2022)
Amina Benarab, Islam Boussaada, Karim Trabelsi, Catherine Bonnet. Multiplicity-Induced-Dominancy property for second-order neutral differential equations with application in oscillation damping. European Journal of Control, 2023, 69, ⟨10.1016/j.ejcon.2022.100721⟩. ⟨hal-03626756⟩
267 Consultations
89 Téléchargements
