Ergodic control of a heterogeneous population and application to electricity pricing - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2022
We consider a control problem for a heterogeneous population composed of customers able to switch at any time between different contracts, depending not only on the tariff conditions but also on the characteristics of each individual. A provider aims to maximize an average gain per time unit, supposing that the population is of infinite size. This leads to an ergodic control problem for a "mean-field" MDP in which the state space is a product of simplices, and the population evolves according to a controlled linear dynamics. By exploiting contraction properties of the dynamics in Hilbert's projective metric, we show that the ergodic eigenproblem admits a solution. This allows us to obtain optimal strategies, and to quantify the gap between steady-state strategies and optimal ones. We illustrate this approach on examples from electricity pricing, and show in particular that the optimal policies may be cyclic-alternating between discount and profit taking stages.
main.pdf (594.96 Ko) Télécharger le fichier
hal-03629189 , version 1 (04-04-2022)
hal-03629189 , version 2 (06-10-2022)
hal-03629189 , version 3 (03-04-2024)
  • HAL Id : hal-03629189 , version 1
Quentin Jacquet, Wim van Ackooij, Clémence Alasseur, Stéphane Gaubert. Ergodic control of a heterogeneous population and application to electricity pricing. 2022. ⟨hal-03629189v1⟩
134 Consultations
50 Téléchargements
