Separation Analysis for Weakest Precondition-based Verification - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2007
Claude Marché
The component-as-array model is a widely used technique for modeling heap memory in Weakest Precondition-based deductive verification of pointer programs. We propose a separation analysis which can be integrated in the core of this model. This allows to greatly simplify the verification conditions generated, and thus greatly helps in proving such pointer programs. We illustrate the improvements both in term of scaling up for codes of large size, and in term of simplification of the reasoning for establishing advanced behaviors.
hubert07hav.pdf (98.73 Ko) Télécharger le fichier
hal-03630177 , version 1 (04-04-2022)
  • HAL Id : hal-03630177 , version 1
Thierry Hubert, Claude Marché. Separation Analysis for Weakest Precondition-based Verification. HAV 2007 - Heap Analysis and Verication, Mar 2007, Braga, Portugal. pp.81--93. ⟨hal-03630177⟩
35 Consultations
35 Téléchargements
