Industry 4.0: Maturity of Automotive Companies in Brazil for the Digitization of Processes - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Sergio Miele Ruggero
  • Fonction : Auteur
  • PersonId : 1061567
José Benedito Sacomano
  • Fonction : Auteur
  • PersonId : 991503
Antonio Carlos Estender
  • Fonction : Auteur
  • PersonId : 1131680
Marcia Silva
  • Fonction : Auteur
  • PersonId : 996298
This article deals with the level of maturity of companies in the automotive segment in Brazil, to carry out the transition to Industry 4.0, in order to identify the degree of maturity of companies in this segment for the digitalization of processes. The data collection took place through a survey sent to directors, managers, supervisors and leaders of companies in the automotive segment. The results obtained indicated that the transition to Industry 4.0, although considered relevant, does not translate into reality for the companies surveyed. The level of infrastructure of the equipment is insufficient, the level of automation is low and the adaptability of the equipment is not yet technically possible in all companies in the segment. There is also no evidence of the use of digital technologies in the production process in approximately 60% of companies, and the maturity in the digitalization of processes occurs at a slow pace.
497439_1_En_16_Chapter.pdf (184.4 Ko) Télécharger le fichier
hal-03630877 , version 1 (05-04-2022)
Paternité
Sergio Miele Ruggero, Nilza Santos, José Benedito Sacomano, Antonio Carlos Estender, Marcia Silva. Industry 4.0: Maturity of Automotive Companies in Brazil for the Digitization of Processes. IFIP International Conference on Advances in Production Management Systems (APMS), Aug 2020, Novi Sad, Serbia. pp.131-138, ⟨10.1007/978-3-030-57993-7_16⟩. ⟨hal-03630877⟩
35 Consultations
57 Téléchargements
