Experimental code and results for the paper "Symmetric Block-Cyclic Distribution: Fewer Communications leads to Faster Dense Cholesky Factorization" - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Logiciel Année : 2022
This archive contains all relevant information to build the software stack used for the experiments presented in the paper "Symmetric Block-Cyclic Distribution: Fewer Communications leads to Faster Dense Cholesky Factorization". It also contains scripts to re-run those experiments and new ones and process the results. All results presented in the paper are archived here as well.
Olivier Beaumont, Philippe Duchon, Julien Langou, Lionel Eyraud-Dubois, Mathieu Verite. Experimental code and results for the paper "Symmetric Block-Cyclic Distribution: Fewer Communications leads to Faster Dense Cholesky Factorization". 2022, ⟨swh:1:dir:c698f3a7e2a1f7c634a8b7eb72c478ebaf28de4c;origin=https://hal.archives-ouvertes.fr/hal-03643569;visit=swh:1:snp:7496c8dd24d10fddde1ed6d60904f47389c711de;anchor=swh:1:rel:3c1b484d6411fe9d80f4801dd9d6b9fadfd6c799;path=/⟩. ⟨hal-03643569v1⟩
200 Consultations
40 Téléchargements
