Agent-Based Modeling for Predicting Pedestrian Trajectories Around an Autonomous Vehicle - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Artificial Intelligence Research Année : 2022
This paper addresses modeling and simulating pedestrian trajectories when interacting with an autonomous vehicle in a shared space. Most pedestrian-vehicle interaction models are not suitable for predicting individual trajectories. Data-driven models yield accurate predictions but lack generalizability to new scenarios, usually do not run in real time and produce results that are poorly explainable. Current expert models do not deal with the diversity of possible pedestrian interactions with the vehicle in a shared space and lack microscopic validation. We propose an expert pedestrian model that combines the social force model and a new decision model for anticipating pedestrian-vehicle interactions. The proposed model integrates different observed pedestrian behaviors, as well as the behaviors of the social groups of pedestrians, in diverse interaction scenarios with a car. We calibrate the model by fitting the parameters values on a training set. We validate the model and evaluate its predictive potential through qualitative and quantitative comparisons with ground truth trajectories. The proposed model reproduces observed behaviors that have not been replicated by the social force model and outperforms the social force model at predicting pedestrian behavior around the vehicle on the used dataset. The model generates explainable and real-time trajectory predictions. Additional evaluation on a new dataset shows that the model generalizes well to new scenarios and can be applied to an autonomous vehicle embedded prediction.
13425-Article (PDF)-30335-1-10-20220419.pdf (10.32 Mo) Télécharger le fichier
hal-03644582 , version 1 (19-04-2022)
Manon Prédhumeau, Lyuba Mancheva, Julie Dugdale, Anne Spalanzani. Agent-Based Modeling for Predicting Pedestrian Trajectories Around an Autonomous Vehicle. Journal of Artificial Intelligence Research, 2022, 73, pp.1385-1433. ⟨10.1613/jair.1.13425⟩. ⟨hal-03644582⟩
189 Consultations
148 Téléchargements
